Carl H »
https://forums.nicoclub.com/carl-h-u9196.html
Sat Jul 17, 2010 9:40 pm
the short simple answer is get a wrench that fits the cam...iirc its close to 26mm and harbor freight sells a long handled wrench that should fit the bill.
I have found that for cams requring single bolts (ka, sr, rb25 vtc) that it is best to have a helper hold the cam in place (with a proper wrench) while you torque it...sometimes a breaker bar is needed to stablize the cam as it will definately try to move against the torque you're gonna be putting on it.
