any tips on replacing the engine air filter?
boxcarbill
Car: '07 Versa SL hatch 6 speed white/beige int.
I don't even know where it is.What is a good price for one, and where to buy? Wally's doesn't have 'em.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
There's not really any tips to replacing it. Replacing the air filter on a Versa is literally the most easiest maintenance I have ever done on any car. There's no way you can NOT know how to do it. Any auto parts store should have it. If not, maybe the dealership won't charge too much for one. Last time I bought a filter, it was under $10.
Above the battery and to the right of the brake fluid resevior is the cover. You squeeze it from both sides and off it pops. Then the filter just pulls out and you drop a new one in. Done and you have spent no more than a minute doing that.
boxcarbill
Thanks, saved me paging through the owner's manual, now I want to ask if there's any reason I can't spray water all over everything in the engine compartment. It's quite dusty in there.I used to do it with my Toyota Tercel and start the engine up to dry off immediately after.
barra
Car: Nissan Tiida S 1.8 t/a
I bought a K&N airfilter.
Take a look here:
http://forums.nissanversa.org/zerothread/443231
In the scangauge screen my car is with 138 hp, i will do a run test with the original filter to see the gain.
boxcarbill
I priced 2 auto parts stores Schucks and Autozone. $20 & $18.Krice!The $20 one was special order and the $18 was an STP.
Shad0wXCalibur
boxcarbill wrote:I priced 2 auto parts stores Schucks and Autozone. $20 & $18.Krice!The $20 one was special order and the $18 was an STP.
I bought the STP one from autozone yesterday actually because I was due for one. Installed it in the parking lot and threw the old one in their trash can.
boxcarbill
My local CarQuest charged me $8.56 for the air filter.
boxcarbill
Good god man, the chamber the air filter fits into was loaded with dried bugs on mine, I had to vac 'em out with the crevice tool.
