Hi, and thanks in advance for the help.
I have a SR20DE that has a bad air leak from the intake gasket. I base that on the engine having an erratic idle and the RPMs jumping when I spray starter fluid on to where the intake meets the head.
Anything to be aware of before I dive in and replace it?
Any other things I should be doing while I have the intake assembly apart?
Thanks!
