Silvia007 »
https://forums.nicoclub.com/silvia007-u255.html
Thu Aug 05, 2004 10:00 pm
You guys know an easy way of replacing valve springs, and or guides?? Well here it is... first get a hose used for compression testing, the end that fits the gauge fits into the hose clamp of a compressor line. Take out the sparkplug to the valve you want to mess with, stick the line in attach the air hose, and bam, when you take off the cam shafts, the valves pop up and you don't have to take off the head or get a valve spring compressor... easy as cake.
