vancouverbc »
https://forums.nicoclub.com/vancouverbc-u10923.html
Wed Jul 20, 2005 8:55 pm
I replaced my calipers/pad/rotors today. The only problem was that some brake fluid came out of the brake hose connector when i depressed brakes to make sure i had bled system right. The connections seemed tight but i tightened some more and it stopped leaking. I can't turn the piston in on the suspect caliper so i assume it is seized up. The outer pad was worn much more in one corner. sliding pins on caliper were not seized up.
Notes:
1. parking brake is easy to disconnect. one 14 mm bolt and just unwedge the cable.push spring back so you can free cable from stay.2. loosen all bolts before removing part or it will be difficult to untighten bolts on part that is not held firmly in place.3. you may have to bleed brakes when tightening brake hose connector bolt as it seemed hard to tighten.4.if you are using vacuum pump($24), test that it will hold a vacuum before loosening 10mm air bleed screw.(have the pump connected to bleed screw and pump up to 20 inches and see if it holds at 20mm)5.The rotor is just sitting there. easily comes off once the two 17mm bolts are removed to release torque member.6.the pads go one easy using sanioll's technigue. slide in at angle and rotate up. the retainers stay in place because of the position of the torque member. 7.remember to keep master cylinder filled as you bleed or if it gets too low air gets in. 8.soak all the bolts with wd40 the night before you plan to disassemble.9.have the replacement caliper ready when you disconnect hose connection to minimize loss of fluid.10. that big thing sticking out of inside pad is a wear indicator.11. left caliper is driver side as indicated by "L" on caliper.
Modified by vancouverbc at 11:05 PM 7/21/2005
