It's variable, from about 8 cm2 to 34 cm2. I don't know what exact values that translates to in the "A/R" world, but it would be from "very small" to "very big". Or do you mean, too big by dimensions to fit inside the engine bay? This has been mounted front-low in a DSM, I think our bays could accomodate it.boost_boy wrote:The VGT is too tricky and the exhaust housing is too big for the CA.
Does this apply to Holsets as well, or only the Garrett VNTs? (which, most of the turbo rebuild shops wouldn't touch with a stick) By fouling up, do you mean filling up with carbon/soot, or getting stuck by thermal expansion?float_6969 wrote:The main problem seem to be that due to the greater efficiency of the diesel engine, the EGT's are lower, and so this technology will work OK with these motors. The higher EGT's on a gasoline engine seem to cause the vane mechanism to foul up pretty regularly when used with gasoline. It seems that they can be dis-assembled, cleaned, and re-assembled and they work again, but it becomes a pain.
Yeah, I was thinking that with the E85, and if this idea does make it's way into my engine bay, it will DEF be running on E85.float_6969 wrote:The shelbe's had the VNT, and ended up discontinuing their use due to carbon fouling.
Don't get me wrong here, it's GREAT idea, and I honestly think that once the materials require to make it work reliably on gasoline become more cost effective, it's going to become commonplace, but as it stands now, it has limited success in gasoline applications.
I would be curious to try it on an engine burning E85, as it seems to burn cleaner and cause less carbon buildup.
As for the actuator, shelby simply had it boost based. The actuator had 2 ports on it, and the unit "failed safe" meaning that w/o any boost input, the vanes would go full "open" and create little to no boost. Then the ECU simply controlled the duty cycle on a 3 port solenoid (1 inlet port, 1 NO port, 1 NC port) based on air flow vs. RPM (AKA boost) and that controlled the angle of the vanes, thereby controlling boost levels. This is exactly how almost all external wastegates work that have 2 ports on them.
Aren't you going S/C w/water to air IC?float_6969 wrote:I might look into this a little more as I'm already burning E85 and I already have a T4 flanged manifold.
Really? What engine management are you running? SDS?float_6969 wrote:I might look into this a little more as I'm already burning E85 and I already have a T4 flanged manifold.
I had to give up on the supercharger. There wasn't enough room unless I ditched the a/c and i've given it up enough times I swore to myself (and my wife and kid) that I would't do that with this car. I am still going to run a water/air intercooler though. i actually just got it mounted up a couple of days ago so I can order intercooler piping.roast wrote:Aren't you going S/C w/water to air IC?float_6969 wrote:I might look into this a little more as I'm already burning E85 and I already have a T4 flanged manifold.
Yup. SDS EM4-F.cdkilla wrote:Really? What engine management are you running? SDS?float_6969 wrote:I might look into this a little more as I'm already burning E85 and I already have a T4 flanged manifold.
