Any technical stuff that's pissed you off about your car???
Chingon
Car: 1991 and 1992 hatchbacks
Well, i thought this would make for an interesting thread... here's my list: BTW no trying to burn the 240, just forming an informative, and therapeutic approach to things..:D
1. The damn battery connections (specially the +) they start rotting like there's no tomorrow, and the miniscule copper "washer" is not worth a ****.
2. The ****ty "door open" switch on the driver's side that makes the open light go crazy...It pisses me off.
3. As of late, my damn starter solenoid is giving me problems...and this seems to happen often.
4. Something that happens often (including to my bro) the stupid master and slave (clutch)...
5. The crappy hatch lock that moves upward and starts making noise.
6. The hood "popping" mechanism that doesn't pop.
7. And this one...oh god, what's with the crappy bolts that seem to strip/break like crazy as if they were plastic?
8. Door seemed to not want to close smoothly either..(but I know there's gotta be a fix).
well, so far that's my rant... ADD yours to the list:pface
240marcuSX
Car: E34 525i
E46 M3
auto seatbeltscrappy rear speakersrusty spoilerseatbelts hesitateugly door carpetlack of turboopen diffshaky windowsleaky sunrooflittle plastic button things that dont come out unless you break themsynchros going bad
corn322
Car: 1993 240sx
the 37 different things that rattle, all at different rpms
EstoMax
Car: 95 240SX KA-t
94 d21 xe 4x4
corn322 wrote:the 37 different things that rattle, all at different rpms
amen. that drives me NUTS!
beside that i hate my door rattle when i close it and the window rattle when i lower it..
max
Prelude Guy
My bogging issue that I have yet to figure out what is causing it. It's so bad I can't even drive it. Too unreliable. Seems like it is eatting up a lot of gas too. :(
i2ice4m3
Car: COUNTERSTRIKE!
1. :Werd on the sunroof2. :Werd on the rattling3. crappy idle sometimes4. high beams dont work5. AC doesnt work6. wind noise from window seal/foam thing7. broken clips-->loose interior panels
SHIFTrl240
Car: 1990 SR20 Sil-80
2009 Yamaha RoadStar Warrior
2017 Alfa Romeo Giulia Ti AWD
i really got no probs other than the rattling ****.
oh and the damn driver seat that has a tear., and the HUD windshield that costs a gold bar to replace.
crzycav86
Car: 93 Nissan 240SX KAT
Stock KA is SLOOOWWW!!!11!1one
93sleeper
Car: S13 project
-Weak brakes (especially the floating caliper design on the rear that tends to wear unevenly..)-Plastic clips for interior panels...even if they weren't any stronger, they should have at least made them all the same design so you could find new ones easily....they all do the same thing anyway...-Power windows catch and shake the entire car when they start to go down-Weak suspension bushings that wear out and creak-Sunroof latch rattles when it's open (well, not after the rear strut bar)-Hatch doesn't always latch when it's shut-My glovebox has a keyhole for a key that I definitely don't have...guess that's just my car...at least I bought it with the glovebox unlocked...-I had the "hood doesn't pop open" problem but then I installed my front strut bar and it pushes up just enough on the insulation on the hood to pop it open nicely :)
But on the other hand it's an awesome car...these things give it personality. They're either easily fixed or very minor. It's pretty mild when stock but is very easy to work on and has a lot of potential for upgrades. I'm glad I got my 240...almost bought a Honda!
eddiec
Car: 91 S13
auto seatbelts
Chingon
i kinda dig the auto seatbelts...and the plastic clips bothered me at the beginning, but after you learn how to take them off, they are no problem.
right now, not being able to turn on the car...no crank (good starter) and I rewired the damn thing.
I also have the problem w/headlights were only one low beam works and I have to turn on the high beams for both to work (weird thing is, one is low and one high)...I did replace the bulbs if you're wondering.
crzycav86
Chingon wrote:i kinda dig the auto seatbelts...and the plastic clips bothered me at the beginning, but after you learn how to take them off, they are no problem.
I just got done fixing my non-starting 240sx. What exactly is your situation? Do you hear the relays click when you try to start the ignition? Maybe I can be of assistance...
wangless
Car: '02 MBP WRX
no radioroof interior "falls" bc it lacks something... i dunno -_-broken speed sensor = unknown speed while driving :(non working odometernon working hudauto seatbelts that wont retract at timescrappy gas milage (probably like 10-15mpg)
i think thats all for now... theres plenty more :(
lilvtboigotrice
Car: 93' 240sx Hatchback SE
sqweeky (sp?) brakesengine rattling at 2k rpm onlystock foam spoilercar wont cold-start unless I tap on the gas for the first time and the rest it starts perfectlynot being able to close the headlights, I can open but can't close them....got to close them manually -_-
other than those, which are only minor problems, its a really strong car with lots of potential. Can't believe I thought about a Honda at one point but glad i stuck to the 240. Owns Hondas any day :ylsuper
btw.....auto seat-belts rock :rolleyes
Chingon
crzycav86 wrote:I just got done fixing my non-starting 240sx. What exactly is your situation? Do you hear the relays click when you try to start the ignition? Maybe I can be of assistance...
yeah..i narrowed it down to a stuck relay (i would guess it's the ignition relay) by the battery bolted to the passenger side fender. Anyways, i hit that biatch and it purred like a kitten afterwards.. So add that to the list...btw anyone know the name or have one I can buy?
crzycav86
Yeah.. that's the one that was giving me problems.
Some people said it's due to the alarm system(that I didn't even know was on the car) was partially disabled or something like that, so it cut power at the relay. So I just bypassed the relay altogether, and it starts up every time.
If you go to the dealership just tell them it's the starter relay.
Chingon
i just thought of something else. Under heavy steering or braking...I hear this loud pop (rarely), as if someone had hammered the underbody of the car. Up to now, I have yet to discover what it is, and my brother has experienced it as well. It could very well be the brake lines going stiff and slapping the fender...who knows?
Chingon
BTW crzycav, that relay is not the equivalent of the starter solenoid right? Our starters have the bendix+solenoid on the starter no?
I just don't want to be solenoid-less if I decide to bypass the realy..
corn322
Car: 1993 240sx
chingon, check you tc bushings
also, I though of another thing that pisses me off:if you just look at the car wrong, it will start to idle bad
s13EastTN
Car: 91 s13 hatch, 95 Honda Civic
1. how when I push in the clutch I have to stare are the rpm gauge to see if it is going to die.2. how I have 4 different keys are my 240, all of which look the same.3. how I have A/c, but alas it does not work4. how my brakes are warped, but are worsened by the fact that my suspensions is tired, so it shakes like a fat man running after the icecream truck.
Ubernoober
Foam wing.Catalytic converter lump on drivers floor.Foam wing.Crap stock motor and transmission mounts.Foam wing.Every piece of smog crap that they COULD have used, they DID.Foam wing.Gas filler that doesn't burp correctly and puts gasoline in the door area. Dumb design.Foam wing.Sunroof that when open is held only by the handle. It looks like it will come flying off on a hard bump.Foam wing.Poorly shaped steering wheel.Did I mention the foam wing? WTH were they thinking?
Turb0wned
1) no ac (i live in miami)2) broken ac3) ac not working4) ugly foam wing like ubernoober said
guyaverage
Car: Nissan 240SX Convertible
Quote »I also have the problem w/headlights were only one low beam works and I have to turn on the high beams for both to work (weird thing is, one is low and one high)...I did replace the bulbs if you're wondering.[/quote]
Chingon, I had the same problem. Take off the steering column trim and unplug and remove the light switch. There is a white semi-opaque plastic plate held on with some plastic rivet-like fasteners. Snap them off. This will get you inside the light switch. Carefully take it apart and clean up the contacts with alcohol and slightly bend them down for better contact. Put it all back together (a drop of epoxy or superglue will reattach the plastic light switch cover to the 'rivets'), slap it back onto the steering column, plug it in and the problem should be solved. Its pretty easy to do, shouldnt take more than an hour start to finish.
My three biggest complaints:
1. Inconsistent idle
2. Steering wheel shake. Goes away, comes back. Goes away, comes back. New tires, rebalanced twice, one new wheel (the others professionally inspected twice), resurfaced brakes, etc. etc. etc. .....Keeps curing itself, then coming back. Two different 93's.. same problem......
3. Cheap seats. Who the hell were these made for? No support, crappy upholstery that wears holes everywhere, crappy foam, ugly seemless fabric.
frapjap
'07 Subaru Legacy
> Crappy idle. > When you think crappy idle goes away, it comes back. > Crappy idle. > Crappy idle gets worse and makes the car shake. > Crappy idle acts up and your car shakes more. > Theres a hot girl in your car, and shes not fat or anything, so the car shakes and she thinks its broken or you're a crappy fix it man > Theres a hot girl in your car and the "2k rpm noise" strikes. Which, by the way is either your heat shield, or heat shield for the cat. I no longer have a heat shield on my headers, so I know its my cat. Still clueless as to where its at exactly. > The stupid speaker wiring. Mine is waaaaay off. > Door carpet! > Non LSD diff. Man, even v6 camaros have posi... > Tach signal being different for dohcs than sohc. I need a 91-93 dohc tach, any sellers? > That piece thats next to the cigarette lighter on the center counsle of the S13 that seems to go missing!
But I love that car sooooo much!
crzycav86
Chingon wrote:BTW crzycav, that relay is not the equivalent of the starter solenoid right? Our starters have the bendix+solenoid on the starter no?
I'm not sure. It's possible that it may be just a relay for the starter's relay... but I just said "relay for the starter" and they got me the right part... which I ended up not even needing.
stfuad
Car: '90 240sx Coupe, '95 3000GT
Yah that plastic thing near the cigarette lighter... heh I found part of it it was broken in half, it was under the console somewhere I think...
Teh shaking suxx0rs
frapjap
'07 Subaru Legacy
My little piece is long gone. Nowhere anywhere under that console. I've been looking thru junkyards to grab it, but the little plastic piece deamon seems to have struck many a 240.
Chingon
yep...shaking @ 70 mph is bad (i blame it on my tires though)...
also, i have noticed poor idle conditions come back when i finish my gas tank (as in all the way down). I blame it on crud at the bottom plugging the injectors. If you have this problem, drop a bottle of seafoam when gas is empty, then fill w/10 bux, and never let it go beneath an /8th again. This has been working for me for many months now. Until recently when i finished the tank again :P
ps: thanks guyaverage...i'll try that.
Chingon
hehe...i'm missing that platic thing..(you're talking about the one that replaces the mirror control in the base model right?)
Also, I can't complain about the open diff. Sure i'd like to have a vlsd or clsd, but c'mon when was the last time you broke your r200?
sirwarrior
wow, lots of complaining. But hey, it could be worse, YOU COULD DRIVE A CIVIC!!!!!!!!!!
