You'll probably find more help in our Hybrids section.kidstayridintheq45 wrote:i just open my shop down in new jersey i am going to be raceing my Q and need some pointers if you have ever seen it done ...i'm gonna put a T5 transmission in ..i got to set the clucth pedal in.do you think the stock rear will hold up against the the motor and trans....i have full flowmaster exhaust...any help will be appreciated ...
You probably want to talk to these guyshttp://forums.nicoclub.com/zeroforum/193kidstayridintheq45 wrote:only things with going with a ford motor 302 is for the fact i cant find aftermarket motor parts for the q45 ...i'm going to be 1/4 mile that bicth i'm putting a pro-charger on that ***** with the stock suspenion and see how it takes it
What is the weak point? Generally the R200's are very, very strong.superuber wrote:The rear diff is a weak point. Esp. if you are putting 500 plus hp on the ground.
Where at? Is the shop in Wildwood? I'll definitely come down and pay a visit.kidstayridintheq45 wrote:i just open my shop down in new jersey i am going to be raceing my Q and need some pointers if you have ever seen it done ...i'm gonna put a T5 transmission in ..i got to set the clucth pedal in.do you think the stock rear will hold up against the the motor and trans....i have full flowmaster exhaust...any help will be appreciated ...
Man, and here I wanted to hybrid my q45 diff to fit in my z31 because I figured the 30spline would be quite a bit stronger than the typical r200.superuber wrote:If you are going to go to that much trouble to put in a ford motor you may as well modify the rear. The rear diff is a weak point. Esp. if you are putting 500 plus hp on the ground. Midnightslidings set up is way different compared to what you are doing.Unless you plan on drifting.
Damn, looks like I read the wrong post before I posted LOL. This is more of what I was looking for.mtcookson wrote:The stock differential is probably one of the strongest R200's out there I believe. The R200 is already a very strong unit but this particular R200 has R230 style output shafts and axles (30 spline flange axle/output shaft and 32 spline axles). It should be able to handle just about whatever you throw at it. One thing to keep in mind though... some have broken even the R230 in the past with manual transmissions simply due to improper use. Clutch drops and the like can and will kill just about any differential you put in there. If driven properly the differential should handle just about any amount of power you can put to it.
Yes actually however, your friend is correct. It makes for piss poor daily driving. Also if you weld the spider gears you have to do VERY good welds. If you do not, you can actually make the diff weaker than it was when it was and open diff or a VLSD. Funny you bring this up, this was one of my thoughts. I am torn though because, my Z is becoming more and more of a race car as time goes on. That was not its intended purpose. It was just supposed to be a badass street car. I guess that went out the window when I install the 10pt cage though. LOL.Haitian_King wrote:A friend of mine was telling me about welding the differential. "Spidering" I think he called it? Either way, it was something along the lines of making both wheels spin at the same speed. He said it works best in track applications because of the dramatic increase in acceleration. But cornering ability is severely decreased. He said that the turning radius gets really wide.
Would that help in this situation?
I agree about the T5... however, they were used in so many different vehicles that there are a lot of performance upgrades for them making them easy to build up for lots of power.ScottJackson wrote:The T5 trans will be the weak link. Those break with stock 5.0 power (if you shift kinda hard). The 302 is also weak. The main webs split above 450hp or so. A 351 is much beefier. Use a TKO500/600 trans with a 351 and you'd have something. Or, a '99+ 3.8litre 4R70W transmission with Baumann controller.
That'll stop us at the free state inspection. But you can pay $70 a gas station aka "private inspection center" and pass.AlabamaDan wrote:Not that it matters to me, but I've heard that if you're in a state that does inspections they won't pass a car with a motor from another manufacturer, i.e. Ford motor in Nissan Car. Just FYI.
