Sushibandito »
https://forums.nicoclub.com/sushibandito-u133627.html
Mon Nov 23, 2009 5:29 pm
I assume by your first post you have a hatchback, otherwise this doesn't apply
My 6.5" speaker sound good, but they have only been powered by the amp. I tried running them off the stock speakers, but the wire must have been bad... Not sure on the write-up on removing the panels, but first offRemove:1) Rear Seats, top and bottom (the tops are held in by two L-shaped brackets on either side, so un-screw from the back of the seat (the trunk part, there are 2 screws, try it with a 10mm socket so you don't strip them) first, then unbolt it from the frame at the bottom of the plastic trim piece.
2) The lower section I believe comes out first, but it will be pretty obvious when you look at how it lines up with the other sections. Just be gentle when pulling so you don't lose the retainer clips.
3) The upper plastic section covers some of the screws in the speaker cover, so this is 3rd. A couple of screws here I think, just underneath the top of the glass on the hatch. They have covers, so flathead those off, then take the screws out.
4) The cover to the speaker is held on by 4 retainer clips, gently pop it off with a flathead.
5) Getting the plastic cover off is a little more complicated, there are 3 screws, one is above the little cover for the rear shocks. You might have to bend out the fabric since you can't remove the rivet without damaging it. The other screw is just below where the strut that holds the hatch up.
There is a wiring diagram somewhere on the positive/negative color codes for the speakers, mine had the crap factory amps, and you might have to splice new connectors onto the ends. I wouldn't bother trying to re-use the amps, its a crappy 5 watts, and the amp in an aftermarket deck should be a bigger improvement anyway.
