BrianHarte wrote:Here is my opinion (KA drifter for 5 years or so)
1. get yourself a nice bucket seat. You will be AMAZED at how much you have to WORK in a stock seat. You slide everywhere. If you get yourself a bucket seat, you won't even think about moving around or bracing your legs or whatever.
2. 2 way LSD. I always suggest this. You DID say you have a welded differential, right? I guess that will work fine.
3. Coilovers. get something that is going to make your car stiff and low. Once you do this, you strongly MIGHT need to get adjustable rear upper control arms.
4. have fun. add parts as needed/wanted.
I drifted my old S14 with a stock radiator forever. You don't NEED a bigger aftermarket one, but it's nice to have.
Don't get rid of that stock clutch fan. Leave it, it works fine.
Don't get an expensive aftermarket drive shaft. I see no need for it at all. I've never had one, I can drift fine.
Bigger stabilizer bars are nice, but not needed. I have stock ones on my S13 and they work. I DO want to get bigger ones though...
As a general rule of thumb, stay away from all those cheap parts you will find on ebay. They are generally mass produced with QUANTITY instead of QUALITY.They might work fine, but they might fail terribly.
Enjoy.Don't spend every dime on the car! Save some too.
THIS^
Two people on this thread have the right Idea.This guy and PJ.Stock driveshaft will work fine, and a 1-piece is a big overkill if your not making a track car. if its your daily, have fun with the noise.
+1 on this being stickied. Coilovers, maintence, Welded (or if you can afford it, but not essential at this point: 2-way differential) RUCAS wouldnt hurt, good tires (Kuhmo XS, or RT615)
If your just learning this is pretty much a great starting setup.A bucket seat and steering wheel (330-350mm) is later on.
A radiator wouldnt hurt at all. and if you do buy a radiator, get a better fan (clutch fan WILL work great, but getting a good fan(s) and buying/making a shroud will help more) before putting a SHO fan in mine after 5 minute exhibitions I'd see the temps go up.. make sure you get good fans with your radiator.
