5upra wrote:well I think I will go for those sdx15's. Just wondering this but how would you rate this setup 1-10(1=weak sauce 10=blow womens clothoff) as far as power and air movement are concerned?
also from another thread of mine...
http://www.partsexpress.com/pe...6-256 and
http://www.partsexpress.com/pe...6-100 are these essentialy the same? FMOD's just need rca connections correct? They would be going to some plain 6.5" woofers and powered by the HU.
Well as long as you can supply your amp with enough power (possibly via upgrading your charging system) and build an enclosure large enough for each driver, it will rock! If you do want those subs, you could even get a more powerful amp...which requires more power upgrades.
See how much space you have and how large of a box you can build.Sealed requires 2.5ft^3 or larger per sub.Ported 4-4.5ft^3 tuned to 25-23hz.If you can't make a sealed box big enough for 2 subs, you can always build one slightly smaller for 1 ported sub.
And if you have any questions about those subs, email or call CSS. They have good customer support and I've talked directly to Bob, the creator of the SDX-15.
I can also charge up my video camera and get you a video of those subs in action if you want. Free air that is
As for your crossover (XO) question, it all depends on how you'll be powering your speakers. If you're using an external amp, don't even worry about it. If you're using your headunit, you'll want that passive 100hz high pass XO, but if you're putting in those subs with that amp, the bass will easily over power the rest of your system!
