This explains the sedan being less reliable than the hatch how?NODES wrote:that is because there is less Sedan's then the hatchbacks.
That makes sense to me but you also have to keep in mind the series of each car. The sedan is the BASE model while the hatchback isn't offered in the base model but in the S and SL. I have a sedan SL and I love it. It's a CVT but so far so good. The cars are generally the same broken down. I can't see how much is different other than the body. They aren't going to build basically 2 different cars just for a hatchback and sedan model.NODES wrote:
now if say 4 out of 10 H/B had issues, that would be 40% failure rate and say 1 of the sedans made had a failure it would mean that 50% are bad.
Now multiply that thousands they sold and you get the bigger picture.
There is more Hatchback versions on the road then there is sedans, I believe Nissan built 70% Hatchbacks and the rest sedans, I read that in an article a while back.
yeah same car, one has a trunk and the other a hatch. They both share the same components that tend to break down on us.Codelicious wrote:
SEDAN FTW!
Not exactly. The Tiida sedan was unveiled on 2004-10-29, less than 30 days behind the Tiida hatch. The two models must have been developed in parallel.roboturner wrote:Here's my guess:
The hatchback is not a new car. It existed for several years overseas before it came to North America, and it has been here for several years since.
The sedan was a variant of the hatch, only built after the car was exported to NA, and made to cater to North Americans, who generally speaking prefer sedans over hatchbacks.
So maybe they haven't had time to iron out wrinkles that are particular to the sedan. I can imagine what those particular wrinkles are, but I'm sure there must be some fairly prominent differences between the two.
