this is the "boost controller" part of it:
$9 pressure relief valve from grainger, part number 5z763. same valve dd uses. you have to take it apart and switch the ball bearing to the other end of the spring (side with red, male threads) and add two barb nipples to convert it to a mbc. twist to adjust. Its good to 20psi
http://www.grainger.com/Graing...item=
the other parts are just brass fittings from your local hardware store, vacumm hose, the solenoid, and a switch to control it.
i'll draw something up once i get it going
