blues14 wrote:Just wondering if anybody who has done this swap regrets it or is very happy with it. my car s14 rb20det 3'' dpipe, I/E , auto ecu, walbro 255 fuel pump, oe z32 fuel filter.everything else is stock.
what kind of hp is this turbo SAFELY capable of supporting without the whole 'ceramic blade shatter' we all hear about?
oh if you have it on hand throw it on, you wont loose anything, compressor exit and compressor elbow are a little biger so go for it.blues14 wrote:i got a link on SDU that said this turbo is capable of 300 hp on an rb20. I have the turbo in hand , but dont wanna waste time and effort. I am only looking for around 250whp,,,,,nothing crazy.
I agree a rb20 is putting out like 190 to the wheels, and the ceramic wheel thing seems to be a hit and miss, ive ran 14 for months straight and recently i hit 20 psi on it for about 5 seconds cause my piece of **** manual boost controler is a piece of ****. my wheel remainsblues14 wrote:i am a firm beleiver that NO rb20det with just I/E and a fmic will put down 240whp. sorry.....its just not happening. it might correct for drivetrain loss and have you around 200-210 atw but thats about it. do people realize that 240whp is around 270-280 at the crank? I dont know about you guys....but i am pretty sure my s14 isnt gonna hang with a EVO / STI with just a couple bolt ons.
anyways...your running 12psi on that rb25 turbo? Isn't that coming close to the whole ceramic wheel shattering thing? if it wasnt for the ceramic wheel....i would just bolt it on. but man.....wouldnt it be great having a turbo where that isnt even a problem?
good question, but the compressor craps out around 15psi so it seems pointless.rb20detsilvia wrote:can you replace those whels with steel wheels
They make cheaper turbo's haha, and i think the rb25 turbine could handle 13-14 cause ive done is for a long time now, and the aussi guys say even 15 safely, but can your fuel system handle it?rb20detsilvia wrote:well looks like there is no point to that if its only good to 15 psi i just dont wanna spend 2000 on a turbo seems like alot to get rid of that stupid ceramic wheel and acually be able to put some psi to the motor
Dose this count? Stock turbo at 14psi, had a intakemanifold on it but I don't think it helped that much. And I kinda bent regulator so the car ran a little lean in the hot dyno room. Ohh untuned PFCblues14 wrote:i am a firm beleiver that NO rb20det with just I/E and a fmic will put down 240whp. sorry.....its just not happening. it might correct for drivetrain loss and have you around 200-210 atw but thats about it. do people realize that 240whp is around 270-280 at the crank? I dont know about you guys....but i am pretty sure my s14 isnt gonna hang with a EVO / STI with just a couple bolt ons.
I drove it at 14psi for a few months before I took the motor out of the S13 I had. I had the walbro aka wallmart 255lph pump on stock regulator. The bent fuel dampner kinda made it lean out vs running at 10.2 lol.blues14 wrote:that is impressive..........but how long will your turbo last at 14psi? is your fuel pump upgraded or running a FPR? that can make your injectors 'act' like they are a little bigger. impressive dyno for a basically stock rb20....... but i must say not a common occurance.
hey I call it 240 lol I round up .Kansei240sx wrote:Hahaha, owned by 4G63 by 1 hp short.
The VG turbo... if you're speaking of the VG30ET turbo, which on the 86's was the biggest TURBINE that nissan released on any car, yet had a small compressor and was only good to an efficiency of 15 psi too.
lol maybe my motor is built internally that i dont know about but yeah sti/evo/350z/g35 all bite the dust from 50 up. I dont know about you but i was about dead even with a chipped 00 s4. Ive run 12psi for the last 2 years so maybe i just have good luck all around.blues14 wrote:i am a firm beleiver that NO rb20det with just I/E and a fmic will put down 240whp. sorry.....its just not happening. it might correct for drivetrain loss and have you around 200-210 atw but thats about it. do people realize that 240whp is around 270-280 at the crank? I dont know about you guys....but i am pretty sure my s14 isnt gonna hang with a EVO / STI with just a couple bolt ons.
Yup 3rd gear pull, the timming was at 20deg since I had a auto ecu. Not sure if that affected the PFC tho since I never did tune it. I just pluged it in and ran it the way it came from japan.blues14 wrote:hey 4g63, is that a 3rd gear pull on that dyno sheet? do you remember what timing you were running?
anyways....I may just go ahead and bolt up the rb25 turbo....I should be able to pull 240whp out of that dam thing.....thats really all i am looking for right now. I did notice the turbo has about 1mm of shaft play....is that alright?
Nope ran fine, had a little hesitation when it was cold but that was 3k for a second.blues14 wrote:i am running the auto ecu too. the car runs like hell at 15, 20 it runs perfect. does your car feel like its 'missing' above 5k rpm when you run at around 15? mine does.
