Any problems with Tanabe springs?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
Riceball88
Car: 2011 Infiniti M37
Hey guys I just bought an 08 Versa and I have a lot of plans for it. I want to get Tanabe springs soon but I'm wondering if you guys have had any problems with a lowered Versa ( i.e. bottoms out, scrapes, broken axles, etc.).
My previous car was an Integra that was really low and I ended up with a bunch of broken axles, tires that lasted 3k miles, and all sorts of other suspension related damage.
I want to make sure this won't happen again :D. Thanks.
t19uz
nope, Totally fine bro till now!
Atx_Versa
Car: 2008 Nissa Versa SL
No problems at all. I have only had some problems facing some steep driveways but no speed bumps or anything.
Gives the V a more agressive look and improves handling dramatically.
MaryB
Car: Versa SL
I have Megan Racing springs and they made my V look so much better!! It handles great also and I've had very little problems except one lil spot but thats just cause its a rise so i just don't go there but they make it look so so much better.
superskunk
Car: '07 Nissan Versa S Hatch
'06 Nissan Murano SL
no problems with the tanabe springs at all.... i didnt even do alignment after install either.... almost 7000 miles on my springs and still going strong....
t19uz
superskunk wrote:no problems with the tanabe springs at all.... i didnt even do alignment after install either.... almost 7000 miles on my springs and still going strong....
hmm i think you should do alignment. toe in.
CodeRed
Car: 2008 Nissan Versa S MT
I haven't had any problems with about 5k miles on them. Make sure you get a full alignment after! You will burn through tires.
Onyxblue
Car: 1990 300zx n/a, 08 Versa SL, 07 Pathfinder SE, 08 Sentra
No problems after 14,000 miles
Shad0wXCalibur
Car: Nissan Versa SL Sedan
If you don't have rough roads and drive carefully (avoid driving onto curbs too high, speed bumps, railroad tracks, etc) then it's fine. Be aware that your struts and shocks may go out sooner than they normally would have and you should always get an alignment even if it looks aligned to your eye.
Gr8dave37
Car: 2008 Blue Onyx Versa S
I have a question on the allignment issue. I had an alignment after I installed my springs and they said that it was fine except the rear which the couldn't do anything about the camber because of the type of rear end it is. Someone else mentioned to me that they should have shimmed it? it's all new to me but can you shim the rear end for the camber?
xtremeversa
Car: 2007 Nissan Versa Hatchback
ive had tanable springs for about 20k miles on my car. im the type ofperson who likes to push things to the limit..... i go 60 miles per hour around on ramps to the interstate... the car doesn't hardly lean!!! they are great springs man! plus everywhere i go, people ask me where i got it lowered... it looks awesome with tanable springs, drives 10x better, and will hold for as long as you have them on there!!!
trust me...
zilvia_brothers
Car: 1987 200sx 5-spd V6
the stock shocks wont blow correct? i was debating whether to go with the springs or coilovers
fastlyfe
great springs. put them on yourself and save money. its easy. . . kinda
superskunk
how funny, i havent been eating through tires with out my alignment... you mite be thinking of other cars... but not the versa... im not the only person with a versa and lowering springs who hasnt done alignment...
versaspeed.com
Car: Viper GTS & SRT10, Prowler, 300ZX TT, Versa SL 6mt, 240SX Race Car w/track records, Titan LE KC
Twenty thousand plus miles here and nothing wrong. And as far as the alignment goes if you feel better doing it go for it....it won't hurt but I did not do an alignment on mine and tire's look great after all the miles and the gang at the SoCalVersaClub have seen the car in person to back me up on that one.
superskunk
see i told you guys... no uneven wear at all on Bob's...
versa19
Car: 2009 Versa
Guys, what is the approximate drop? Also, can someone measure the clearance from the bottom of the front bumper to the ground? thanks
Return to “Versa Technical Discussions”
