Now I have mispelled Rogue. Just to help myself: It's not Rogue,its not Rogue, its not Rogue, its not RogueTicmxman wrote:No problems at all and no regrets. My only regret is that I have not driven the Rougue for two days while we had rain chances and it was in the garage staying clean I find the Rogue a blast to drive. Take a look at my likes and dislikes topic.
I have felt what you are describing but IMO Nissan has the RPM/CVT set up at the limit to not be a problem as the Rogue is now... I do not think of it as a current problem. I don't know that I would even call it currently a vibration, it is very close to creating a vibration though. We will see as the miles rollup if it is a problem in the future.computerguy wrote:With the CVT you actually have a direct drive like a standard transmission and you are experiencing the same vibration you get with a standard when you lug it. Nissan should have programmed the CVT to keep the RPMs up a couple of hundred RPM. I guess gas mileage was more important
There's a thread over at the FreshAlloy forum with some pictures:sskylor wrote:Well what do you know, you all participating in this forum know a lot.I just ran out to find the cargo light and well there it was in the left upper corner of the hatch door. Thanks for the heads up. Also I did not know about the kick plates option, I may look into that. I am seriously considering getting what is called a clear bra protection installed. I am reading it does a fabulous job at preventing rock chips. The are a number of manufactures like 3m and Invisiguard that make kits to fit the car. Has anyone ever used this for their new cars before???
Anyone have a picture of the "kick plates"? I hate door dings.Roguerunner wrote:They do have a cargo light (in the sl.) The first night I had mine,I was disappointed because I didn't think it had a light back there. Then my dad found it! When you lift up the back door,look up & to the left & the light is on the inside of the door. Just flip the switch & it will start working! Also,they have what they call kick plates available for the Rogue. They are made of PVC & painted to match your color. They keep you from getting door-dinged!
YES to all of the above, HOWEVER not at the same time. You can only choose for it to display one of the items at a time, and it can't automatically shift among the dispays -- you have to manually choose which display you want at any given time.CTRogue wrote:What does it display for the XM? Does it show the artist and song name? does it show the station name?
