Any place close to Illinois/ in illinois to get a crank collar fixed?
Mistaken
Car: 93 240sx Coupe
Like the title says looking for a place in or near Illinois that is reputable to get a crank collar fixed on a S1 RB25det.
l0nestar
Car: 1993 Nissan 250SX
2004 Toyota Altezza
1963 Chevy Impala SS
I had mine fixed at a local shop in about 3-4 hrs south of you (Terre Haute).
Cost me $100 to build the collar, crank machined, collar installed, and micro-polished.
I'm trying to remember where Andy (Booztd 3) had his done at - it would be much closer to you.
Modified by l0nestar at 10:49 AM 5/23/2008
240z4u
Car: '95 Nissan 240SX
I had my crank snout welded, ground, and rebalanced at a place down south in LaSalle. It was pretty expensive at 300 bucks or so.
If you want more info, I can try to find out who it was.
Thanks - Evan
Mistaken
Car: 93 240sx Coupe
How was the quality of work from both shops? I'm not quite shure what this would cost me but was ready to stomach a couple hundred if i had to for good machine work. Is it worth it to get the crank balanced while im at it?
Darius
Car: RB25DET S14 - 665 WHP (SOLD)
Any decent machine shop can install the crank collar if they have a lathe. It is best if you go through the instructions with them to be sure that they understand what is needed. For welding, they would just have to match the existing oil pump drive diameter and flat spot (forget the name of it).
If you're using the collar (JUN), it probably doesn't NEED to be balanced if it is installed according to instructions.
If it is welded on, a lot of heat can be involved and warp the crank. In that case, balancing it is essential.
Coolwhip
Vendor
Car: RB26 Raw Brokerage War Machine
Most machine shops will be able to do it without a problem. But then again, being picky on machine shops is a good practice.
Since the majority of the weight or change there of is happening to the center (and not on the outer edges like the counter weights).
But regardless, balancing is a minor procedure to have done if your crank is going to be out anyways.
240z4u
Mistaken wrote:How was the quality of work from both shops? I'm not quite shure what this would cost me but was ready to stomach a couple hundred if i had to for good machine work. Is it worth it to get the crank balanced while im at it?
Just to clarify, I didn't use a collar. Machine work was great! I would do it again. At the time, the collar was VERY difficult to come by (about 3 years ago).
Evan
Mistaken
Car: 93 240sx Coupe
Well any other information on the shops would be great... like a name, phone number, address. I am hoping to get the crank in there as soon as possible.
bumblebtuna
Car: rb25/26 2fotay
if you think your crank is warped you can use a dial indicator to see if it's within factory specs. i had my neo25 crank welded but the guy welded the entire diameter of the snout and needs to be grinded down. even with the coloration and heat dispensed the indicator read it to be true to spec. the heat on the snout doesn't seem to be an issue because of the location on the crank.
anyone wants it it's fo sale in my sig... just needs the metal grinded smooth. should run about $50-$100
Modified by bumblebtuna at 5:10 PM 5/23/2008
Modified by bumblebtuna at 3:49 AM 5/24/2008
Mistaken
Car: 93 240sx Coupe
Bump any information?
240z4u
Ill call my old machine shop and get the info for you tomorrow.
240sxr33
Car: Cars (imports)
Integrity Automotive Machine Engine rebuilders2858 N. CiceroCicero and Diversey(773) 282-9200Ask for Paul.
Mistaken
Car: 93 240sx Coupe
Figures i get out of work at 4:00 and integrity closes at 4:30. Granted its only like 8 miles from my house and about 16 miles from work... with traffic ill never make it there before it closes.
Mistaken
Car: 93 240sx Coupe
Any idea how long average turn around on a crank is from the machine shop? I dropped my crank off at integrity yesturday just wondering when i should expect it back by.
Darius
Depends on if they do it inhouse or have their crankshaft stuff subbed out. Shouldn't take more than a week though.
Mistaken
Car: 93 240sx Coupe
Apparently they only do crank shafts but sounds good. Should give me enough time to finish stitch welding the frame and painting the engine bay. Also im working on a plenum and ITB setup .
Mistaken
Car: 93 240sx Coupe
Integrity wouldnt do it. Any other shop suggestions?
