I know this is bad but can someone use paint and highlight it for me?DammitBobby wrote:
If you look you will see the butterfly valve under the FPR. Only the S13`s have butterfly valves. The reason the FPR vacuum line is different is because I removed all the other crap and needed a vacuum source for the butterfly valves.Craving4Boost wrote:looks like a s14 motor? his is s13. the FPR fuel hose and vacuum is lined up differently but shouldnt be a problem. i was asssuming he had a s13 motor
