It appears the tires will be more squared and less trapezoidal in cross section. I find each of those XXR tires to be weighed at 23.1 lbs. The larger tire will also weigh more than the smaller tire, the one you listed I find at about 25.5 lbs, though I actually didn't find the type and size combination you have listed at Tire Rack. You can compare the weight of the combined wheel and tire for your current setup (I don't know what that is, take your wheel off and weigh it) and your desired setup (about 48.6 lbs). You can calculate that into a ratio or percentage to have it make more sense. Tire rack tends to have approximate weight for tires, so you can look into that data there.
This is a tire and wheel calculator I've found. It lets you measure your wheel well rim and suspension and you put those numbers in to check for fitment clearances. Even without adding your own measurements, it makes nice pictures using the known sizes of your wheels and tires.
http://www.wheel-size.com/calc/?wheel1= ... 18X7.5ET45
I found this other article about sizing wheels. It reminds me that tires get harder as they get wider and that tire pressure is an important adjustment to consider as well.
http://www.popularmechanics.com/cars/ho ... 2/4281033/
I did find some specs on Altima wheels from the factory. These cars have pretty big wheels compared to my 240sx. I didn't realize that, so your numbers seemed huge to me. Again it's all relative, that is why I asked you to please tell me the size you currently have, so I could speak relative to your situation.
Opinion (also subject to change) - For your car, these tires and wheels seem lumbering and cumbersome, but not as much as I was thinking last week. The factory size for the 3.5 seems pretty good to me and I'd tweak those numbers if it were my car.
Also, note your center bore and get the appropriate adapters. Stock is 66.1mm and those XXRs are 73.1mm. I have a similar thing with my wheels and have aluminum rings to fill that gap.
I would make a little chart and put your stock setup in there and the new setup and a few things to compare like cost, weight, size, contact patch (if you can figure that out). Then you can weigh the pros and cons of changing your setup. It's just an idea. You don't have to think about it that much. You can just put some wheels on. I'm pretty sure the stuff you suggested will fit and won't break your car or wallet. If you use that calculator and add some of your car's specific measurements, you can be more confident in the fitment/ clearance.
