Any other nissan radio a direct swap to the versa?
The Nissan Versa Tech Discussion forum is the place to discuss Versa performance modifications and maintenance.
mhardgrove
Car: 2009 Versa S
I found a 09 sentra radio and was curious if it is a direct swap for the unit in the Versa?
Shad0wXCalibur
Car: Nissan Versa SL Sedan
The plugs on the Sentra and Versa radio look exactly the same and both cars use the same aftermarket wiring harness so I would say that a Sentra radio will drop in just as well as a Versa radio. People do this all the time with other makes of cars. The only thing I'm not sure of is the brackets. It may not mount even if it will plug in and function.
Modified by Shad0wXCalibur at 11:23 AM 9/16/2009
Codelicious
Car: 1989 Nissan 240SX
mhardgrove wrote:I found a 09 sentra radio and was curious if it is a direct swap for the unit in the Versa?
I believe that the Cube radios will fit into the Versa. I have heard that the new 2010 Versa's have the Cube radio in them now so it shouldn't be a problem.
I'd check with someone first though because I don't have a Cube so I can't verify this...
Return to “Versa Technical Discussions”
