boost_boy »
https://forums.nicoclub.com/boost-boy-u2853.html
Mon Apr 26, 2004 1:11 pm
Quote »source/cost of these regrinds ? other valvetrain mods/cost ?[/quote] I've tried every frickin' experiment except the CA20DET hybrid thing and that's only because I just don't see the need for the few extra ponies/ few extra $$$s theory when you can take a completely stock CA18DET, dress it up with all the insurance parts such as (But not limited to) pistons, rods, cams, etc and get some seriously wicked and reliable power out of these little puppies. I've tried the CA16 cams and I didn't see a big difference in the CA16DE's camshafts. I've tried the CA18DE's camshafts and the car had a little more low end grunt and all these were with JWT ecus and between my two sentras.
I installed a set of regrinds and these showed a significant improvement in overall performance, but moreso in the mid and upper rpm ranges. Now I have the HKS 264 with the 8.5mm lifts and they perform like my regrinds, but have the fancy name.
I have another set of regrinds: intake 276 duration with a 11.5mm lift and exhaust is a 268 with an 11.25mm lift. I originally was going to use these cams in my built engine, but I opted to test the JUN 272s with the 10.5mm lift and the JUN solid lifter kit.
If you have a standalone ecu, you can better adjust your car to any engine modification and get the most out of any mod, even if it's just some stock N/A camshafts. If you're trying to gain big power just by adding on camshafts and no ecu work, then you all got another thing coming and that's for sure.
Dee
