Any one tried fitting an K&N heat shield on a Injen intake?
All things Altima Coupe.
weix
Car: 08 Altima Coupe
Any one tried fitting an K&N heat sheild on a Injen intake? I am talking about the 2.5L Altima Coupe. The heat shield for Injen just does not seem to protect from the summer heat at all.... K&N is selling the shield for hundred something... Part #07691
SHIFT_COUPE
Car: 2014 Infiniti Q50 AWD
I don't believe I've seen that done. Be the guinea pig!
Welcome to NICO btw!
LongBeachCoupe
Car: 08 Altima Coupe (RIP Hurricane Sandy)
2005 Lexus RX
big waste of money if you ask me!
IBCoupe
Car: '08 Nissan Altima Coupe 3.5SE
'19 Infiniti QX50 FWD
'17 BMW 330e iPerformance
Does the K&N heatshield actually help? I'm sort of hesitant to buy an intake without some kind of heat protection.
dldjros69
Car: 2012 Evo Gsr
A/C 2.5 Turbo 6MT (SOLD)
LongBeachCoupe wrote:big waste of money if you ask me!
Why do you say that?
I like how it diverts the outside air directly into to the filter.
And it seems to block some direct heat from coming off the engine. Id say its worth it.
It also makes your engine bay look hot!!!!!!!!!!!
dangeris
Car: 08 Code Red 3.5
08 BMW 328xi Coupe
90 300ZX 2+0 NA
weix wrote: The heat shield for Injen just does not seem to protect from the summer heat at all....
That is not the purpose of the heat shield. :facepalm: :slap: It was never designed to protect the filter from the heat of the summer air but rather protect it from the heat generated by the motor/transmission when at a stand still and divert the flow of on coming air towards the filter when moving. :yesnod
Oh and welcome to NICO! :)
toxik
Car: 09 Pearl White 370z
having a heat shield is very important, a heat soaked intake will make you lose power, so in that case you just shelled out X amount of dollars for an intake that will give u -5hp... and who wants that?
try to fabricate your own heatshield, if k&n doesnt fit!
johnnir3volution
Car: 09 nissan altima
I have the k&n heat shield with the takeda intake and it fits fine
mmx23z
Car: 2008 A/C 2.5s CVT
i was gonna try this, but ended up buying the header instead, i have the injen intake right now too & i dunno if uve ever drivin with the heatshield off... but it makes a big differece. but i think you should try it, if not im still gonna try it but not till the end of june or july... i got some bills comming up
IBCoupe
Not sure if I should do that or rims, next. Leaning towards intake/shield because it'll be significantly cheaper. Maybe rims next spring.
chrispizzitola
Car: 09 BLK Altima Coupe 2.5s
link on where to buy
