darinz »
https://forums.nicoclub.com/darinz-u47224.html
Fri Dec 08, 2006 7:35 pm
Hopefully do OBC and the XI in 2008, but it's going to cost around $30k so have to get a few more good sponsors to be able to do it.As far as fitting the motor in. I'd shift the body back as your appraoch angle is then about 80 degrees! With 37's you'll be able to drive into a brick wall! I've shifted mine back 75mm. You'll have to fit a remote oil filter, the PS alternator and aircon will have to be changed. I'm just fitting a 70amp 24v alternator which will go where the standard alt was but you have to completely remove all factory brakets. I'm using a VL commy PS pump and mounting it in factory position.The turbo is going to be mounted in front of the engine as there is so much room between the engine and the radiator. Air filter etc has yet to be looked at but I think my 4" snorkel will need to be modified, I think it'll end up like Cass's one. It appears my truck will be racing again at about 1900 to 1950 kgs with about 500hp. Should go quite well then I think!!!!!!!!!!All I can say is the sooner you start the sooner you can drive it!
