The CA MAF is your problem, get a Z32 Maf it will solve your problems.TurboFortysx wrote:
Mods:GT2871RFMIC560cc injectors255lph pump--------------->CA maf<-------------Crappy Emanage
His original problem was going lean around 4k rpm, with a CA maf, so the original problem still exists and it isn't the maf. Right now, I think it's a wiring issue unless you fried the maf when connecting and disconnecting wires.OmarM wrote:The CA MAF is your problem, get a Z32 Maf it will solve your problems.
