bosch non-turbo 300zx is exact same as RB25detDustinZ wrote:I need an O2 sensor for a RB25DET. Mine is bad and I can't find the interchange for it. Any help would be appreciated.
DustinZ
DustinZ wrote:I already figured it out over a month ago, actually right after posting. I had a couple of z32 o2 sensors and installed one and checked output with consult and perfect match. The bosch part number is different but it is the same sensor just with a longer wire. The plugs are the same too. 90-95 z32 will work for sure. 96+ might but they are obd2.
Dustin
