float_6969 »
https://forums.nicoclub.com/float-6969-u780.html
Mon Jan 26, 2004 7:36 pm
Yea, I have an idea to make it work, I'm just not sure if it will work yet. So here is the deal. The 2 pumps are identical except for the inlet and outlet and the pulleys. If you compare the units, the only difference between the 2 pulles is that one has the space at the back and one has it at the front. I know there has to be a way to get that pully off because I know you can change the clutch. If you could just swap the pulley's everything would line up perfect and you'd have no squealing and the origanal lines to boot! Now I just have to wait till it gets about 12 degrees outside so I can test this theory out.
