z32pilot62 wrote:Just a crazy thought but is there a pilot bearing in there for a Manual trans and you are trying to bolt up an Autotragic? I could totally be wrong but its worth a shot. Also did you make sure the ground cable was out of the way? Other than that it should slide in easy without needing a good thrust or ramming lol
Nah man, nothing like that in the way. That's what I keep thinking, shouldn't need that much of a push to slide forward.
Ace2cool wrote:I didn't know yours was A/T too.....
Sadly it is, but it's been too much fun and has taken much abuse without taking a dump. Until then, the trans stays...
Chase300 wrote:The torque converter is keyed, the hole is circular with one straight edge, you have to align the transmission into the keyed hole first before it will "slide" in.
its easiest to look at your transmission to see where about the straight edge is on the pin then turn your crank so that the torque converter is roughly sitting about the same way then just rock it back and forth slightly till it goes in. Good luck
So are you saying it might be easier to have the TC bolted up to the flexplate while it's on the motor? Then just try rocking on to the trans when trying to "stab" it? I'm doing all this while it's in the car and I had the TC seated before trying to bolt up, but I think every time I bolt it to the flex plate it gets pulled out slightly so it's not fully seated.
You suggest I try it like this?
