Any Oil Loss Experience With Switch to Synthetic Engine Oil?
Thoughtful_One
Car: 1998 Nissan 240SX SE
2000 Honda Insight
I've had my SR for about a year, and I started using synthetic oil during my last oi change (Amsoil 10W-30).
I had my engine leakdown tested and all cylinders were under 7%, which is good, about 8 months ago, and have not made any real changes besides a Greddy FMIC and Blitz SS air filter.
I've never exerienced any oil loss before, and when I checked today, I found I was 1/2 quart low! I filled it up, and I will check more carefully.
Has anybody ever experienced oil loss when switching to synthetic? I never lost any oil with the other non-syntheitc oils I was suing (Usually Mobil Extended Performance Non-Synthetic).
I know 1/2 quart is not a lot, but I plan to leakdown test gain in a few weeks to makes sure all is good before I up the boost.
supreamS14
Car: 96 240sx S13-blacktop Sr20deT
Synthetic oil can seep past worn seal's more than regular oil.
Thoughtful_One
2000 Honda Insight
Engine has new front and rear main seals...
Engine never burned through any oil before.
supreamS14
Piston rings? Valve stem seals? Head gasket? Blow-by?
vocationalzero
Car: 92 Too For Dee
87 BMW 635 CSi
06 Dodge Dakota Night Runner Edition
06 Nissan Sentra S
The molecules in synthetic oil are thinner/smaller than the ones in conventional oil so they can get through worn seals/parts easier and show leaks.
