Any oil leaks yet on any of you hi miler owners?
boxcarbill
Car: '07 Versa SL hatch 6 speed white/beige int.
Did another oil change on my V yesterday (13,666 miles) and she is dry on the bottom. Just wondering how long that will last.
alonsorules8
Car: 2008 Nissan Versa SL HB
I'm at 40k miles with no leaks.
kc5f
Car: 2008 Nissan Versa SL HB CVT (daughter)
2007's Nissan Versa (both RIP)
2012 Nissan Versa
2015 Nissan Versa Note
2016 Nissan Juke.
I park mine in the same place every day and it's clean. Still lovin' it!
boxcarbill
I was hoping you'd chime in. You have the high miles all right so far.Thanks for the replies.
Bubs daddy
Car: 2007 Nissan Versa SL
ABS, CVT
28,000 miles. Over 2 1/2 years old. Sound as a pound.
Shad0wXCalibur
Car: Nissan Versa SL Sedan
I would hope a car doesn't start leaking before 50,000 miles. I'd be buying another car real fast...
fjwagner
Car: 2008 Nissan Versa S et al
Shad0wXCalibur wrote:I would hope a car doesn't start leaking before 50,000 miles. I'd be buying another car real fast...
usually just a manifold gasket or oil pan gasket. Pretty cheap repair even if it did leak. A lot less than a new car.
boxcarbill
My previous car was a 1987 Tercel wagon with 175k. It was wet from oil underneath but no drips after three days after an oil change. The filter screwed right onto the block horizontally and oil ran down to take it off.
I'm planning to replace those little plastic plug clips on the V, that hold the plastic cowling on under the oil filter, with sheet metal speed nuts and use 1/4" bolts to hold it on. Dirt in those plastic plug clips really makes them difficult to get off.
Juelze
Car: 2010 Nissan Rogue 360 AWD
41,000 miles on my 07 Versa, and it's developed a small oil leak. I brought it into the dealer on Monday and they put some dye in it and said it appears to be coming from the top of the motor. I'm bringing it in on Monday to have a tech check out where the leak is coming from with a blacklight. Luckily, it should be covered by the power train warranty. However, I've lost faith in the Nissan brand when a 3 year old car is leaking oil already.
Knightro2
52,000 miles on my 08 V...no leakage as of yet on anything.
br4dysays
Car: 06 Nissan Altima SE-R
approaching 60k and no leaks here
aidan80
Car: Versa 1.8 Manual
I'd be not be expecting any leaks for a long time yet. The first car I'd driven in the US was a manual 98 Saturn SL and the last time I had driven it even looked under it there was a good 140k on the clock and no leaks, the radiator had spring a leak by then. Although it did do what the other Saturn's of the same series do best burn oil! I'm hoping not to see anything leaking in this car before it hit's 100k I'd not be impressed if there were.
srellim234
Car: 2007 Nissan Versa SL hatch w/CVT
(sold 08/2011)
2008 Toyota Prius
(purchased 04/2016)
35,000 miles and 35 months- not a drop.
bigdaddychia
Car: 2007 Versa 2006 Quest
He asked for high mileage owners. 28k isnt high miles. 220k is and no I have no oil leaks. n Or leaks of any kind for that matter
xtwoonamatchx
I have about 36,000 miles on my car and it has developed a little leak it seems. I haven't had a chance to put it on ramps to check, but any suggestions as to what could be leaking? Other than the obvious loose drain plug and filter?
