srellim234, let me also make a few points:
• I do know what the difference is between Stop/Go city driving thank you, driving up La Cieniga or Wilshire certainly constitutes that even at 6:22am! I do go home at 4:00pm and get caught in traffic on PCH and on occasion the 10. I do admit my driving on the Freeway in the morning is brisk, but when I take the canyons I use more gas similar to stop/go though I don't think as bad. The technique I use with traffic is try not to stop but creep with a big enough gap between me and the car ahead, I know it's hard but if you can do as much as possible it helps. I also try to time the lights so as to keep as many green as possible. Old techniques, but sometimes work. It's not Rocket science!
• Safety ratings were not mentioned initially, but I thought this was a discussion and I could contribute any information that should be taken into account, after all I now feel as if I'm on trial and have to defend my economy numbers! Yes it's no Hummer but 2700lbs+ is heavy for a car of this class. And I'm sure safety was one of the pluses with a lot of the buyers of the Versa including myself.
• Tweaks, as you call them, Do you even know what a Scan Gauge is?
http://www.pureenergysystems.com/store/Scan_Gauge/It's a computer that communicates with the main computer on the car. It does nothing to the engine or the car, I have it programmed right now to give me real time INFORMATION as to what my gas pedal pressure is doing to my fuel consumption. I've inflated the tires within spec. These to me are not tweaks. What I call tweaks are Front Air Dam to improve Aero or Take out the back seats and interior panels or what ever to maybe reduce weight, or put an overdrive on, etc. Maybe you and those 44 other Versa owners should get a Scan Gauge, it may help you all with your driving habits and most likely get better fuel economy like I do.
Just because you and 44 other owners are getting less economy does not mean that's the way it is, it could mean that 45 people drive with a lead foot. I and I'm sure a number of other CVT owners are getting the combined numbers I'm getting and they as well as I have no reason to lie about it. Maybe it's a problem with '07s that they fixed with the '08s. Are you sure there's nothing wrong with your EFI? or?
BTW: I'm not in conflict with you, I'm just trying to put my $.02 in, Cheers.
