any Mod for a stiff clutch pedal?
nismo1003
Car: Ka24de
Got a Aftermarket ACT Clutch for awhile, it still takes alot of pressure to press the clutch , are there any springs or DIY mod for the clutch pedal to make it easlier to press? for those who installed the ACT clutch? did u do anything to make it softer?
I drive a Altima, the stock clutch is so stiff to press already and now obviously it's way too stiff , u think I can just use a bigger Master clutch cylinder and a stiffer springs for the clutch pedals? are most of the nissan/infiniti use the same master clutch cylinder? if u know anythinga bout it , would you give me the part number and stuff. THANK YOU ALOT
s13sr20chris
a bigger master cyl would make it more stiff. you want a smaller one. the tradeoff is pedal stroke. with a softer pedal you get a longer stroke. if the stock clutch is too hard then any performance clutch will be at least as hard. unless you had a multi disk setup that was custom made to be soft.
IvoryJ30t
Car: 95 Maxima GLE, 95 Maxima GXE
come on now, an act clutch isnt that stiff. i find it to be perfect, i wish all car clutches felt like that.
i cant stand soft clutch pedals.
s13sr20chris
you may want to check for mechanical probs if your stock clutch felt very heavy.
D Money
Car: driving illegaly
when i got rid of the clutch dampner it made my already light clutch outrageously light. shouldnt this be in a different section?
s13sr20chris
yes
navysnail
i THINK i remember seeing somthing a while back that nismo makes a master and slave cylinder kit that changes the ratio, you may want to look into that, although im not 100% sure that they make one
