CoupeS13 »
https://forums.nicoclub.com/coupes13-u127705.html
Wed Mar 04, 2009 6:31 pm
So I am currently in the middle of finishing my 5 speed swap on my s13. My only concern at the moment is my Flywheel. I took it to get it resurfaced because thats just what u do when you replace a clutch... Anyways this is a used flywheel I bought, when i got it didn't seem like it was beat up on... it wasn't glazed or anything major (Maybe some hotspots but I don't even know if you could call it that). Anyways on the pictures below you can see the flywheel is not even... Or is it??? Maybe there was a high spot on the flywheel. Also you can see there is a Step almost all around the ring but not on one spot....
So my question is.... If the flywheel is really even like the machine shop says it is should I go ahead and put it on? or should I buy another flywheel and get it resurfaced at a different machine shop?
