Any Leaking OEM sunroof's..??
rn240sx
Car: 12 Frontier V6 (supercharged)
98 240sx ka-t (fully built)
09 Ninja 650R
06 Suzuki S40
15 Hyundai Santa-Fe 2.0T
Any 95-98's out there experienced a leaking oem sunroof yet..??
What was the problem...??Im trying to decide whether i should buy a 98 with an oem sunroof OR buy a 98 without a sunroof and have one professionally installed..
ThanksRobert
Doomed2Walk
Car: 2005 Subaru Impreza WRX STi WRBP on gold
Someone cracked the wooden thingajiggy on my sunroof, but still no leaks
Cyberkreig
Car: 1993 Nissan 240SX SR
In my S13 with OEM sunroof The dome light will fill with water if it rains REALLY hard.. But nothing else seems to get wet.
Phax
Car: Control dynamics
My S13 sunroof leaks. If I were you in your position, I'd skip the sunroof all together. Unless it's stupid expensive, I'm going to have mine removed.
574-240sx
Car: Nissans, Toyotas, Subaru
I park my S13 in the garage because the rear hatch leaks by the spoiler. I would trust the sunroof to keep my dry in a downpoor. I had to replace the glass assymbly in my maxima because nissan doesn't sell just the weather stripping, it is a 97 too.
twofourzeroSX
Car: 91 sileighty
my roof rusted out alittle bit and leaked like crazy due to a kink in the drainage hose. the kink is taken out and rust is gone, replaced with bondo. no leaks yet. skip the sunroof theres no need
98s14inaz
Car: 2010 Nissan Titan Quad Cab
rn240sx wrote:Any 95-98's out there experienced a leaking oem sunroof yet..??
ThanksRobert
If it does leak just buy the new rubber seal from nissan and install it yourself. A factory sunroof is better anyday of the week than an aftermarket one. If you are really into autoX or drifting I wouldn't recommend the sun roof because one they are heavy and two it weakens the structural integrity of the unibody. If I had it to do all over again I would have got an s14 with out the sun roof.
whosurdaddy018
my 97 sunroof has never leaked if tha helps u any
