Any known products/tricks for curing this age old problem?
Jagstang
Car: 1995 S14 w/ Kouki S14 SR20DET
Yeah, so I found out that my front right shock tower is finally beginning to rust on my 1995 240sx. . . As you can see it's not too bad.
So is there any cheap known durable products, or tricks in preventing this cancer from further spreading?
Thanks, help would be greatly appreciated.
Modified by Jagstang at 3:57 PM 3/29/2010
breaker77
sand it off, then paint it
blamo!
Rex
Car: None
Never used it myself, but know a few people that have with good results.http://www.por15.com/
keith0486
breaker77 wrote:sand it off, then paint it
blamo!
Jagstang
blamo!
What kind of paint would you recommend I use (besides Rex's useful suggestion about the por15 product).
Modified by Jagstang at 4:08 PM 3/29/2010
breaker77
by the looks of it...
black paint..
Jagstang
breaker77 wrote:by the looks of it...
black paint..
I mean what kind of paint product should I use that contains rust protection?
breaker77
well if you want to be super anal then prime it first with whatever says it has rust inhibitor in it, then shoot it with the black.
Crazyirish
Car: Nothing noteworthy at the moment...
Remove the rust before using rust inhibitor + paint. A wire wheel should do the trick.
zach-Ka
Car: 1990 240sx (SR)
1.Grind it till all is gone.2.Treat it with chemicals.(I dont know what it's called but at the shop they have this stuff that turns any rust into workable metal.)3.Prime and base with rustolium.4.Clear coat.That should do the trick.
