MinisterofDOOM »
https://forums.nicoclub.com/ministerofdoom-u16506.html
Mon May 07, 2007 3:39 pm
Yeah, the VG has a timing belt which needs to be changed. I think dealer recommendation back when the car was new was every 60k miles. Newer VGs (like in the late-90's Pathfinders) had a longer belt change duration, probably due to better belts. I'd ask your dealer to be sure...Mine went nearly 130k on it's second belt with no ill effects, but I don't know that I'd recommend chancing that.
The VG is really a good motor. It's fairly simple and therefore not very problem prone. There were issues with bad exhaust manifold studs that cause leaking exhaust manifolds (generally the leak seals at normal operating temp), and there were common issues with cruise control. Aside from that, they're very stout and dependable. The exhaust stud issue is merely an annoyance and doesn't inhibit performance at all (unless you're running turbo...). Cruise control issue is the same--it won't cause problems, it simply doesn't work.
The automatic transmission is another thing entirely. They're prone to failure from heat, and also not the best for tons of power. If you were to build one up, it'd be okay, but stock they're pretty weak. If you have a 5 speed you have nothing to worry about.
I'd recommend building the VG30E rather than swapping. The VG30DE isn't anywhere near a drop-in affair (the two motors are more different than their names imply). You could also look into turbocharging it. If you were to refurb it to like-new, you'd have a pretty good car, though. 160 hp and 180 ft lb sounds low, but the car's pretty small and it's enough to move it. Put some effort into suspension and chassis stiffening and the VG's wide powerband will be more than enough for some fun on the track.
