RT22 »
https://forums.nicoclub.com/rt22-u137418.html
Fri Jul 22, 2011 10:15 am
I got one from a junk yard, actually picked up 2 that were in better shape than mine. Just remember when you pull off the old one the peg will drop so when you put it on it will not be accurate. depending one which one is needed this is what I did. My speedo went bent. I got a buddy to pace me at 55 mph read tach and then removed speedo pointer. We removed the plastic cover got in top gear at 55 according to tach remove and popped on speedo pointer. Took 2 folks one driving one doing the work. On mine the speedo has a stop peg and when removing the pointer it moved so just putting it on at rest had speedo way off. if tach is off you need to find what RPM a working one just like yours is pulling at say 55 get to 55 and put tach needle on at the right position. Hope that makes sense, you have to know what speed and rpm is at a set speed get to that speed and put needle on at that speed and or rpm reading to be accurate.
