beans33 wrote:well i put my timing belt back on and it didnt start. i did a compression check it came up 120, 0 ,0 ,0 . I was just checking jsut incase it bent my valves with a incorrect install of the timing belt
Are the cams lined-up correctly? Please check it again before you determine you need valves. And even so, you'll need to find out how many valves you bent. I do have valves available, but you need to see if you've damaged your motor because if that compression test is correct, you've definitely bent a gang of valves.
Dee
