any ka user heard of these yet...
Roger_cha
Car: 91 nissan 240sx
i was suffering on the net trying to look for some plug and wires for my ka but came across these... http://www.vividracing.com/cat....html
has anyone ever used them yet and whats the performance on them.
Doya
Car: '95 240sx KA-T
Why do you need to upgrade your ignition. Do you have a turbo or something. There really isn't any other reason why you would need that.
Wc240
Car: 89 Nissan 240SX
97 Nissan 200SX
91 Nissan 240SX ka-t
06 Scion xB
2000 Nissan Frontier
didnt know up'n your ignition system requires a turbo, you learn something everyday
OP, i believe theres more to it than just those. i dont think they are just plug n play
volcomskater773
Car: S14
seems like an msd doesnt it?
mckmnstr
Car: 1995 240sx
well just cause the spark is hotter that does not mean the fuel will burn faster. a puddle of gasoline burns just as fast from a lit match as it does from a welding torch. burn is burn.... id say when you drop in a big bad a** motor and your tuning for balls to the wall everything you got... then you might just take that mild boost of ignition. otherwise i wouldn't waste time on lil upgrades id be getting better equipment for that price to improve my handling while saving for an engine swap... oh wait that is what im doing any way you dont have to listen to me thats just me voicing opinion
moso
Car: 89 240sx ka24de 5spd
90 240sx ka24de RIP
most high end ignition upgrades are to help deal with high compression which makes it hard to fire plugs. if your compression is stock than these would probably be overkill. get a blaster coil and some nice wires.
Doya
Car: '95 240sx KA-T
Wc240 wrote:didnt know up'n your ignition system requires a turbo, you learn something everyday
I never said that upgrading your ignition system requires a turbo I was just trying to say that there is no need to upgrade your ignition like that unless you have a modded motor.
Roger_cha
well im just checking to see if anyone heard of these yet. im not going all out with my ka im getting some magnacore wires..
