KATwo40 »
https://forums.nicoclub.com/katwo40-u25350.html
Sun Aug 06, 2006 5:25 am
Sorry for the delay, but I've been CRAZY busy with work, and we've had rain every afternoon.
So, pardon the dark pics, but here are some shots of my DP.
The setup is:
Garrett T3/T04E (.63 a/r exhaust)SSAC TopmountCustom 3" DP
You can see that it's close, but it's been that way all summer and no ill effects, yet. The A/C line doesn't actually touch the DP, but it is VERY close. I'd recommend at least wrapping the DP, and as mentioned above, wrapping the A/C line probably is a good idea, too. I might do that when I slap this new engine in there.
I also plan to put a couple washers behind the brake booster on the passenger side to c*** it slightly toward the driver side. That manifold makes the turbine housing VERY close to the BMC.
(CLICK FOR LARGER IMAGE)
