any ka-et running on a t25
214kka-et240sx
Car: nissan s13 silvia
my set up is a ka-et on a t25 turbo boosting 10 on stock injectors, walbro f/p ,safc and not tuned yet and it makes 175hp 200trq
also it has 233k miles
214kka-et240sx
check out my s13 at car domain at (sidewayss13) give your opinion
erollinc
isnt 10 psi too much for stock injectors?.....
sdtouge
Car: 1990 240sx coupe
ya. thats skethcy.
skatanic28
Car: 96 240sx
damn man you are really pushing those 270's at that power level. considering an fmu or 370's?
cosmo
214kka-et240sx wrote: boosting 10 on stock injectors,
*shudders*
214kka-et240sx
cosmo you are cool ka all the way
sil80drifter
Car: 1990 240SX Hatch
WHP?? or crank HP?bear in mind that the SR20 makes 200 crank HP at 7psi with bigger injectors. And that those guys usually don't push THEIR (370cc) injectors past 15 psi without an FMU/SAFC. You must be either careless, or very aware of your timing. And SAFC can only do so much with stock 270cc injectors.... why risk a good setup when you can get an RRFPR?.
sil80
214kka-et240sx
it runs too rich on stock injectors at 10psi but with a sr i ran a guy with a sr boosting 10 psi had a fmic and a exhaust system from HKS and had a SAFC and i still pulled hard on him and i only make 175 hp 200 trq at the wheels dont get it
sil80drifter wrote:WHP?? or crank HP?bear in mind that the SR20 makes 200 crank HP at 7psi with bigger injectors. And that those guys usually don't push THEIR (370cc) injectors past 15 psi without an FMU/SAFC. You must be either careless, or very aware of your timing. And SAFC can only do so much with stock 270cc injectors.... why risk a good setup when you can get an RRFPR?.
sil80
Structure240sx
how do u know it runs too rich?
Nismo_Freak
Car: 89 Nissan 240SX
214kka-et240sx wrote: my set up is a ka-et on a t25 turbo boosting 10 on stock injectors, walbro f/p ,safc and not tuned yet and it makes 175hp 200trq
You are running at above 100% injector duty.
Increase fuel pressure or put in 370's or you will have custom vented pistons very soon.
Jookmasta
many factors could contribute to u keepin up with that sr. whats ur timing at? what's ur afrs? i think u should definitely consider an fmu or safc w/ bigger injectors. As a matter of fact, since u use top feed injectors, u have no excuse for not using larger injectors as 440cc injectors can be had for under 100 bux from various engines..............
sil80drifter
correctomundo.i like custom vented pistons, they make the engine breathe better. til it dies of course.
edit: whoa. 1000 posts. that's weird.
sil80
214kka-et240sx
timing at 12 d run rich cause when i dynoed it the guy told me it was running rich b/w 5k 6k rpm and it spits out flames so its rich on stock injector and it starts pulling at 1200rpm till red line
Nismo_Freak
214kka-et240sx wrote:timing at 12 d run rich cause when i dynoed it the guy told me it was running rich b/w 5k 6k rpm and it spits out flames so its rich on stock injector and it starts pulling at 1200rpm till red line
It's not rich.
It is physically impossible for it to be overly rich if those are the numbers you are putting down.
It puts out flames because you let off on a turbocharged engine. My N/a KA used to put out flames too, it was not running rich.
jmhalder
Car: base model 95 S14, steeliez, boosted on the T25, going to HY-35, and 650's/N60/walbro/bikirom to han
yeah, seriously, get like z32 injectors, or ghetto rig somethin up, come on!!!
kamikazestorm420
post pics of your engine bay
AllAboutDaZ
Car: 300zx tt
the car is not running rich like the people are saying and iu had told you before those injectors are maxed out alreadyand yes keep boosting it too high and you will have custom pistons alright and a knocking motor
