BlackBirdVQ »
https://forums.nicoclub.com/blackbirdvq-u32517.html
Mon Feb 06, 2006 8:52 pm
Well, you can overcome the understeer problem fairly eassy in my case. I run JIC FLTA2 coil overs which I can change the spring rates on fairly eassy. Personally I am going with stiffer than front spring rates for the spring. I have found out from my own testing that stiffer rear springs add LOTs of oversteer, and those larger rear contact patches will help even out the handling. Another benefit I see is able to corner weight the car properly for my type of driving- road racing. As silly as it sounds, my only 2900lbs Maxima does fairly well considering it has lots of usable powerband, and fair amount of power vs 4 cylinders and other NA 6 cylinders.
But like you said, staggered is really for looks only, and in MY case it works really good (stiffer rear springs), and i hate the way the rear wheels are tucked in way too far inward. Ahhh the great mutli-link beam suspension.... dumb Nissan.
