Haitian_King »
https://forums.nicoclub.com/haitian-king-u54261.html
Thu Feb 21, 2008 2:24 pm
Injectors 1, 2, and 8 are pretty easy to remove/install. All the other ones require plenum removal. If you can ohm your injectors and narrow it down, you can easily get it replaced. Now, if it happens to be one of the ones under the plenum, then you might as well give it the old college try and inspect/replace the hoses down there.
You'll have removed the plenum already to do the knock sensors if I'm not mistaken. If you're not going to do it yourself, you should find all the relevant material from the board and bring it to whatever shop you take the Q to. At least you'll know the steps and be able to watch the mechanic.
