Any ideas what is wrong?
icee20
Car: 1996 Pathrfinder 4x4 LE
Hi guys and gals, I have a question. I have a 96 Pathfinder and recently my steering has been acting up. there is huge dead spot right in the center of my turning radius, so when I go between right and left or vise versa, I have to turn alot more then it should. When in the dead spot the wheels do not move as far as I know just when I get to the edge of the dead spot. Any info is great, just would like an idea what is wrong before I take it in to the mechanic when my tax return comes in.
Thank you for the help
Towncivilian
2007 Nissan Altima 2.5L CVT
2012 Infiniti G37 Sedan 7A/T
Checked the fluid level yet? What's its condition - is it brown or black, or smelling burnt?
icee20
it is a light brown and smells a little burnt but I don't know what is actually supposed to smell like
Towncivilian
It's not supposed to be brown or burnt smelling. Buy a quart of synthetic ATF that meets Dexron III specification and a turkey baster and suck out some old fluid and pour the new fluid in; do this with a few miles of driving in between until you're out of the quart. This should change most of the fluid.
icee20
but would bad fluid cause the dead spot in my turning radius?
Towncivilian
Not sure, but old dirty fluid is bad regardless. Fluid is the cheapest thing to try.
icee20
Quick update: took it in to get it looked at..the problem was that my bushings were blown out that were holding the rack @ pinion...got it fixed...still working on changing fluid....thanx for the help
