180fan »
https://forums.nicoclub.com/180fan-u3602.html
Mon Dec 22, 2003 10:42 am
Glaze on your rotors are a possibility. If they have a slightly blue tint to them then you've found your glaze. Your pads should need replacement if the inner section of the pads are worn down to about 1.0mm of thickness. The shims are a possibility, if the grease between the pad and the shim is gone, then the thin metal shims will vibrate and squeal. It also depends on the pad, if you're running metal based pads, then you'll experience squeal when not braking hard. Check those out.
