With the temperatures dropping week after week, it's kinda hard to see the effects of anything I try.
007jpang wrote:also how do you change the transmission fluid????
You can look around for a more thorough explaination, but changing the ATF is a PITA. You have a few options, you can either have it hooked up to a machine that will flush the entire system and fill it with all new ATF. The downside of it is that the filter won't get replaced. In hindsight I don't think leaving in the old filter is a big deal, the filter looks like window mosquito netting, I can't imagine it filtering anything.
Another popular option if you're really into doing it yourself is dropping the fluid pan. Once it's dropped, you can change the filter, however you only get to replace half the fluid this way because the other half is stuck in the torque converter. It takes a couple hours to do this and it's rather messy and all you really get out of it is that you can change that damn mosquito netting filter. You also get to check underneath your car every day for the next week to make sure the new gasket isn't leaking. Some mechanics have said that to change the remaining fluid in the torque converter, you can reroute the return line to a container and run the engine in gear while also filling it up with new fluid as the old stuff leaves the return line. This only seems to work if the fluid system went, pan->torque converter->radiator->pan. Instead the 240 seems to go pan->radiator->torque converter->pan because it didn't seem to matter which line I rerouted, anything coming in or out of the radiator was new fluid, not the old stuff in the torque.
A lazy way of doing it that I've heard but haven't tried is stick a tube down the dipstick and start a siphon. It's really slow and takes hours for the siphon to work and only gets half the fluid just like pan dropping method and doesn't even change the filter but it's a lot easier and cleaner.
Probably the easiest do-it-yourself method to change all the fluid that I "think" will work is to reroute both inlet and outlet of the radiator to their appropriate drain pan and container of new ATF. Let whatever is in the radiator naturally drainout. Then let the engine run for an appropriate amount of time for it to cycle through the fluid once.
In hindsight, my suggestions are:Pay to have it hooked up to the machine to flush the system.
If you really want to change the filter, try the siphoning trick the night before, that way dropping the pan won't be as messy.
I think very few people properly maintain their Auto transmission anyways or as the schedule describes because car manufacturers wouldn't have made it nearly impossible for all the fluid and filter to be replaced if it was such a concern for people (unless this is their way of having the cars die by around 150k).
Use synthetic because that way you won't feel as bad about neglecting to change the ATF when you should.
