Any idea?
unknown007
Car: White 1993 Q45 (G50)
Where i can find some good long lasting pulleys and belts?Mine are squeeky high pitch follow by my lifters.
Q45denver
Car: 1995 Infiniti Q45t
1990 Infiniti Q45
1998 Nissan Frontier
You can replace the idler pulley bearings fairly cheap. Napa should have some.
unknown007
what is your meaning of cheap?well do yout hink it maybe the pulleys?belts?or pulley bearings?
When i hit past 3500rmp squeals like a pig and then sometimes i turn it on and it does a short squeal.Pulleys?
The ticking are the lifters because it goes away after 2mins.
5zigen
check your belts, if they're fine then its your idler pulleys. you will need to take them out and have the bearings pressed back in.
go to http://www.vxb.com and search for bearing #6301RS and those are the bearings that are used on Nissan idlers
unknown007
5zigen wrote:check your belts, if they're fine then its your idler pulleys. you will need to take them out and have the bearings pressed back in.
Ok should i buy the 10 bearing set or just one?once i do that it should go away?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
You need 6 bearings on the VH41DE as two are pulleys are double bearings. If the belts are not less than a year old, replace them also. But the best grade of bearing, not the lower ones and don't buy Chinese sourced ones.
slybydesignq45t
Car: City Bus
Seeing as I had the dealership change this for me prior to agreeing to buy the car, they purchased 2 belts, and OEM pully from the Infiniti dealership for around or under $100. It took the mechanic about an 1 hour to properly install both. I asked if it was OK to watch as he did it and it wasn't that bad of a job. I think the OEM pully was $70 from dealership.
goody90q45
Car: 1992 Infiniti Q45 (sold)
unknown007 wrote:Ok should i buy the 10 bearing set or just one?once i do that it should go away?
You can check the pulleys one at a time by removing the belt and running the engine. If the noise goes away you've found the bad bearing. Once you remove the pulley, it should rotate freely with no noise or grinding. If it shows any of these 3 symptoms replace it.
I'm not sure that I would trust bearings in my Q that only cost $2/ea. An option for you is to drive to the local Motion Industries outlet and purchase OEM NTN bearings for about $15/ea, maybe less if can wrangle a discount. You'll need 4. Here's a link to the set I purchased and had pressed in at work.
zerothread/259050
They have stores close to you in Concord, Gilroy and Sacto. It loks like you can create an account and order online.
motionindustries.com
unknown007
zerothread/259050
I would do that but are you telling me to drive with out one pulley at a time?you cant hear it while it ildes like i said it screeches when im driving at high rpms.
Thanks for helping me guys.I'll just buy all bearings and replace.good idea?
goody90q45
unknown007 wrote:
I would do that but are you telling me to drive with out one pulley at a time?you cant hear it while it idles like i said it screeches when im driving at high rpms
Rev the engine in park. If you have the belt off it's very easy to remove the pulley.
unknown007
One problem when i do that it still doesn't sound.It's hard to explain but i'll try that as well.Thanks.I should be replacing the bearing right?
jimbyjimb
If the whining noise can't be heard by revving the engine in park then your bearings probably aren't what's wrong. Belts don't care if the engine is loaded or not. Is the noise in any way related to the A/C cycling?
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
slybydesignq45t wrote:Seeing as I had the dealership change this for me prior to agreeing to buy the car, they purchased 2 belts, ...
But there are 4 belts on a VH41DE and they and any failing pulley are always replace at once to avoid repeated labor soon after. Belts are cheap.
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
goody94q45 wrote:I'm not sure that I would trust bearings in my Q that only cost $2/ea. An option for you is to drive to the local Motion Industries outlet and purchase OEM NTN bearings for about $15/ea, maybe less if can wrangle a discount. You'll need 4. Here's a link to the set I purchased and had pressed in at work.
zerothread/259050
Retail for the good bearings is about $20 each. And there are 6 required as two of the pulleys are double bearings.
Modified by maxnix at 7:29 AM 6/23/2008
Q45denver
1990 Infiniti Q45
unknown007
jimbyjimb wrote:If the whining noise can't be heard by revving the engine in park then your bearings probably aren't what's wrong. Belts don't care if the engine is loaded or not. Is the noise in any way related to the A/C cycling?
I don't use the A/C even if it's 100 outside i rather save gas and sweat then cool of and pay.Honestly when i sweat it doesn't bother me i just turn it on when it gets out of hand.
So i doubt it's anything with the A/C or can it?
qship96
Car: 1996 Infiniti Q45
Must not have a girlfriend/wife......they are not fans of ball musk!
unknown007
qship96 wrote:Must not have a girlfriend/wife......they are not fans of ball musk!
I have a girlfriend she goes through it but once i notice she cant i turn it on.Or sometimes i will just because i dont want her sweaty.
She perfers her 97 camry with the A/C on then the Q with it off hahaha.....
maxnix
1995 Infiniti Q45t
2000 Infiniti Q45
AC will help gas mileage at highway speeds.
Sweat and leather not a good combination, even with girlfriends aside.
