Hijacker »
https://forums.nicoclub.com/hijacker-u9394.html
Mon Jul 31, 2006 12:56 pm
you should have stated that in the original post, emotion. We can't help you if you don't give us all the info.
As far as the popping and smoking. Does it only pop and smoke under load, or when you're sitting in neutral and revving as well?
Have you checked your timing to make sure you're not out of timing somehow? when the popping and smoking happens, can you hear what may be a valve rattle?
