Any help installing a nitrous wet kit into an sr would be nice...
GoldWatchKid
Car: 240Z
Ok, so im having some trouble trying to understand how the kit works. I bout the kit used. I believe I have everything except the switches.
Im def a nitrous noob.
Im installing it into my sr20det. My basic questions are
a. where do I tap for nitrous?
b. What/how do I hook the fule line up?
Any pics and instructions would be nice. The brand is NOS. I think its there basic kit. Im attaching a picture to show exactlly what I have.
Thanks
AkademikONE
Tap the intake tube right before the intake manifold.
GoldWatchKid
Car: 240Z
I thought you did that only for dry kits?
AkademikONE
Unless it's a direct port system, which I'm sure yours is not, tap the intake tube right before the intake manifold. It doesn't matter if it's wet or dry.
Beemen550
Car: 89' 240sx SR20DET
A. drill a hole in your coldpipe, but not to big u dont want it to leak, about 4-8 inches from the throttle body, make sure u seal it good or u will have a boost leak
B. u will need a fuel line splitter, u can buy the pieces at lowes, auto zone, etc. then cut the fuel line right after the fuel filter and put the splitter in, and run it to the fuel jet
i wouldnt't recommend anything bigger than a 50shot on a stock setup, and u better have a bigger fuel pump or i wouldnt run any
GoldWatchKid
Car: 240Z
Well I have a walbro and a frontmount. I als have an upgraded ecu, so I don't have fuel cut.
Anyways, I'm using the original coldpipe. How can I properly tap a whole into that without it leaking?
Thanks
* any pics would help *
Jesse SR20
Car: 1990 S13 fastback
A wet kit adds the nitrous after the fuel (or maybe it's the throttle body).
A dry kit adds it before.
Sounds to me like you need to leave the installation to a professional.
GoldWatchKid
Car: 240Z
I was thinking the same thing.
There's gotta be someone on here that has nos on there stock sr20det...
