Any guess on my RWHP for this set-up?
zeeth2800
Car: 92 hatch sr20det
what you guess im pussing with this setup.
redtop SR 15psi through a t-30stock injectorsstock ECUtop mount manifoldFMIC3in turbo backK&N cone sound motor with good compression
what you thinking the numbers are with this?
twinspoool
Car: S14 zenki
sounds like 500rwhp easy.hahah dyno time
kentuckyslider
Car: 02 IS300 manual/03 G35 sedan auto
zeeth2800 wrote:what you guess im pussing with this setup.
I can tell you are confused. 15psi thru stock injectors and no tune???? It will hit 240whp once, right before it blows up!
Sleeper_RMS13
Car: 91 FB W/Blacktop SR
Kentuckyslider is right. With out injectors and a proper tune it wont last. A gt30 at 15 psi is way more than a t25 at 15 psi. And if the ecu doesnt know that then BOOM. Buy yourself some 550 or 740's and get a tune. Do it right the first time or start all over. Other than that 350hp+ easily.
zeeth2800
Sleeper_RMS13 wrote:Kentuckyslider is right. With out injectors and a proper tune it wont last. A gt30 at 15 psi is way more than a t25 at 15 psi. And if the ecu doesnt know that then BOOM. Buy yourself some 550 or 740's and get a tune. Do it right the first time or start all over. Other than that 350hp+ easily.
s*** guys it sounds scary haha.i just picked up the car so thats why its such a weird build.
i will be picking up 550 injectors and a aem standalone within a month or so.
kentuckyslider
If you're going stand alone then get at least 740's to match your turbos capabilities. I would get a jwt rom tune and some 72lbers. I made 411whp with that setup and a GT30R and it is very streetable.
