Any grease fittings on AWD models?
bimbamboom
Just wondering if there are any grease fittings on the driveshaft of AWD models. If there are then I like to make the lube shops guys aware of them. Otherwise the fittings could be overlooked.Thanks
philipa_240sx
AFAIK there are no grease fittings anywhere on the Rogue. Alot of the ball joints, U joints, bushings, etc are permanently sealed and do not require periodic lubrication.
I looked over the Service Manual and the only items relating to 'regular maintenance' on AWD models is the rear diff and transfer case oil. Even then, Nissan only recommends fluid changes every 30,000 miles (48,000 km) or 24 months if you tow a trailer.
Return to “Rogue Forum”
